AZCummins
- Joined
- Aug 21, 2023
Bought this used and ran it on my truck for several months. Removed to go with a Calibrated Power Tune. Mostly just used it for EB memory, throttle sensitivity, tire size calibration, and TPMS changes so do not have much feedback on power levels as I left it on stock setting with +3 throttle sensitivity.
One clip has small piece broken - pictured in last photo
Asking $300 shipped in continental UPS via UPS ground
From website:
From website:
Features:
- 5 Power Levels Adjustable on-the-fly through steering wheel controls
- Level 1 - 20hp/55tq, Level 2 30hp/70tq, Level 3 40hp/90tq, Level 4 50hp/110tq, Level 5 60hp/130tq (Peak to Peak Gains)
- User adjustable throttle booster settings in each power level via app
- Tire Size Speedo Calibration via App (Up to 40" Tire Size)
- Button Recall Enable/Disable via app - Remembers Tow/Haul and Exhaust Brake settings
- Turbo Timer Setup and Enable/Disable via app - Once enable, feature will work on every engine shutoff cycle
- Tire Pressure Monitoring Sensors Enable/Disable, Warning On/Off, and Pressure Threshold adjust via app
- Engine High Idle adjustable through steering wheel controls when in Park
- Max Cruise set speed adjustable via app (Set max cruise speed at 40-97mph)
- Gear Display in Drive on factory display Enable/Disable via app
- Fog Beams with High Beams Enable/Disable via app
- Gear Ratio Calibration via App
- Manual DPF Regen via app
- Read and clear ECM/TCM diagnostic codes via app
- Check Emissions Readiness monitors via app
- Engine Coolant Protection (Module adds no power until 120-degree ECT, backs down power at 240-degrees ECT)
- Now supports 2019-2024 Ram Cab & Chassis 3500/4500/5500
