2023 3500 SRW with factory rear air leveling - lift or leveling kit to fit 37" tires suggestion??
Mxz0588
Apr 23, 2024
Hey Guys,
I just ordered Thurens .5" front lift with shocks all around as I have factory air ride on my 24' Laramie. Whats the largest tire/wheel combo I can run? Im looking at 20x10 - 19 offset with ether 35x12.5 or 11.5 wide if I am going to rub. I use my truck to tow all the time so I want to avoid rubbing if I can, but .5" is not a lot of gain on the front lift. thanks in advance.
Hey Guys,
20x10 with a -19 offset?
Mxz0588
Apr 23, 2024
GR1MxREAPER
May 4, 2024
Whether you level with .50 or 3” the tire will run the same basically. You need to pull the front fender liner back towards rear of truck and trim the pinch weld a little to run 10 wide
