Aisin Transmission 2024 Ram 3500 code PO869
Misc12900
Feb 26, 2024
2024 Ram 3500 with 1100 miles through code PO869 after start up from intersection then hard shift, went to limp mode, restarted truck now drives normal, any one experience this?
RamCares
RamCares Team
Mar 25, 2019
Hi Misc, we see that you have a similar thread regarding the same concern for your 2024 Ram 3500. As stated in the other thread, code P0869 indicates that the "Governor Solenoid Voltage is too low, and it likely needs replacing. However, this is only speculation, and it would be best to connect you with a dealership who may be able to service your vehicles hands-on. Should you decide to seek servicing, reach out to us, and we will do our best to further assist. Thanks!
Chris,
Ram Cares
Misc12900
Feb 26, 2024
Thanks the dealer may have found a connector that was not seated properly, and the code PO869 read to high of line pressure, which could be related to the voltage being to low. with over 80 sensors on this truck i guess they might not all sink up at times.
