unfortunately after only a year of owner ship and thinking i had done nearly everything i could to keep the stock motor from going bad im pretty sure cylinder 6 has sent its rod bearing packing.
definitely going with a built motor as i owe 60 left on 2018 and love the truck just hate the reliabillity i never got out of any of it
questions.:>:>
whats the go to for rods for extreme towing and performance
bearing brand
cam
rocker and bridges
basically what brands are the guys who bild these motors using for such
im very hard on trucks. sad that my hd truck couldnt handle the abuse that my tundra did with 3 times the miles
to help heres the back story. i replaced intake with the big horn and the intake plate with grid delete. egr and def delete. 4 inch exhaust all the way back. 3 months later at 80k miles trans went. replaced with stock through warranty thankfully. upgraded trans with ats valve body, ats trans controller, bds trans cooler bypass valve, trans pressure harness increase to i believe 190. head studs and because of a noob moment not checking bridge after install i bent a pushrod so replaced them all with oversized performance ones. ended up braking stud on injector so purchased stage 3 injectors and cp3 pump. started the delete with a race me ultra tune then after injectors had another company do a tune over email with the stock file. ran better... now 3 weeks after i purchased a 48 foot toy hauler to make life easier for racing my motorcycle and decided i would use it over the winter in texas as i work out there and live in flordia and get tired of hotels. about half way there i started to hear a knock. i was pulling in race mode but!!!!!! i am ocd about keeping temps down and trans was the only temp i had to worry about at times as i didnt want to go over 205 with it at max. oil got 220 one time duriong the trip and coolant to 212. trailer loaded is roughly 16k. my work trailer ipulled for 5 years with my tundra is 9k and temps werre at the same area months back. so obviously when the noise started i pulled off the next exit to get fuel and check it out. was only under throttle at first. checked fluid everything was good. went to get back on the road as i pulled out it got worse. pulled over again and pulled valve cover to see if maybe i had broke a valve spring as i also started to develope the exhaust chirp when using exhaust brake. ran it with cover off to see as nothing was visiblly off nor could i move anything. it all operated fine and noise was minimal and not a color of shavings in the oil flowing as i have spun alot of bearings when i was younger and know what to look for with it. climbed under truck and was stupid loud at back of pan.. now have a shop in louisianna looking at it as the dealer there swears its the motor even though i think they just charged me for a diagnosis and didnt even look knowing whats done to the truck.
hopefully these guys listen to me and check for the flex plate first to hopefully be something simple, but in my mind i do believe its the rod bearing and she will need a new motor or build. whats your guys opinions on the build or should i just buy one built. shop will do whatever i want. found a stock motor for 9k and a pretty built motor for 15k but its a 6 to 8 week lead time for it and really dont want another 10k out for just a rental truck but, i will wait if it is the better option.
questions.:>:>
bearing brand
cam
rocker and bridges
