I had one installed in my '05. Only complaint was that the gas struts wore out. Geno's replaced them once. I gave up after that. There was no problem with installation.Has anyone here bought/installed the Geno's Garage "Splash Wham-o" tailgate protector? I am looking at buying one, but was hoping to see some better pictures of one installed on a tailgate. The pics on Geno's site are from too high an angle to see how far down the outside part goes under the bend on the tailgate. If someone here has one, could you please post a couple of pics?
I think you may have one product confused with another?I had one installed in my '05. Only complaint was that the gas struts wore out. Geno's replaced them once. I gave up after that. There was no problem with installation.
Wonder if this would work with a Bakflip MX4 ?
I would be all over that if I didn't have a softopper. thinking about a work around.
It’s not a 100% perfect fit, where it curves under there is a small gap like the lowest angle is a bit too tight. Still ok imho. Better than the factory for sure.
I'm not using it as it came from factory. I modified it with magnetic strips.If you are using your topper with the factory trim that on the tailgate right now, it should work.
No sir.Did you leave the factory trim piece on? Looks like it's sitting high. Mine fits perfect.
