New 2024 leaking fluids
Tell3131
Jan 26, 2020
Noticed 3 spots in driveway from new 2024 2500 (Cummins). Fluid appears to be redish. Got under truck and saw couple places that seemed to be leaking. Any ideas? Taking to dealer tomorrow. My guess is transmission. Maybe the fluid is leaking/running to other areas as well? Just seems strange there would be 3 leaks.
Enve46
Jul 20, 2021
Oof, looks like trans fluid if it’s oily and looks like oil leak where the engine and trans meet. Either way not fun for new truck
Tell3131
Jan 26, 2020
Only 400 miles on it so far. Taking it to dealer tomorrow to see what they say. Hoping it’s an easy fix. I’ll post on here what they find.
LegendaryLawman
Legendary Pessimist
Oct 20, 2022
My father’s 22 had a small drop of red fluid, wiped it and it didn’t come back at all. I figured maybe something during the assembly. 1.5 years and 16k miles no issues. Yours looks like more of an issue though… Probably bad seal.
flan
Aug 16, 2019
It looks like your transfercase output shaft seal is the main culprit. The little drip on your bellhousing may be assembly lube. I’d wipe that and check back. Do get it looked at by the dealer though.
Units
Nov 17, 2023
South Ms.
Had the exact same thing on my ‘23, transfer case shaft seal. Fixed under warranty. Looks like the residual you see on the heat shield is from the shaft spinning and slinging fluid. This was mine -
Jeeper93436
Oct 6, 2023
My 23 had something that looked like oil in the front of the bell housing. When I wiped it I noticed it was kinda sticky. I assumed it was some sort of assembly lube, I haven’t seen anything since.
mbarber84
Sep 10, 2021
Washington County, PA
Definitely T-case output seal.
The fluid on the engine adapter plate and inspection cover of the Transmission may be the CATS rust preventative that they spray on to the block for shipping and storage protection. I would recommend wiping it off with a degreaser or solvent and then see if it returns. IMG_3224.jpeg
RamCares
RamCares Team
Mar 25, 2019
View attachment 71539View attachment 71540View attachment 71541
We can certainly understand your frustration in regard to this concern. Our team would like to offer you support while your vehicle is being serviced. If you would like assistance,
please send us a private message with your VIN, mileage and the name and address of your dealership, so we can dig deeper. Thanks.
Chris,
Ram Cares
BilletWilson
Feb 6, 2019
The transfer case output shaft was leaking on my 23 with less than 1,000 miles so the dealer replaced it. Just hit 10,000 miles so I did an oil change and found the output shaft leaking again :mad:
keltek_nw
Jan 18, 2019
My 2023 Ram 3500 has the same thing. Just noticed today. Only 5500 miles on it.IMG_6544.jpeg
