Noob 3500 owner with P026B Code
wisportsnut
Apr 11, 2024
Hi everyone, I just took delivery of a 2020 3500 Laramie last night, dove it home 100ish miles, drove 40 miles to work this am, and on the way home check engine light came on, P026B code thrown. Where do I start??? I see a lot of good info here just hard to find out what I should do first? Oh, 45K miles on it... any advice? First time diesel owner... tx!!! Oh cummins turbo diesel dually...
flan
Aug 16, 2019
That’s a somewhat common code that will pop up after the Y78 recall is completed. I wonder if your truck was done right before the sale and you are another statistic. Most everyone resets it and it does not come back. Probably worth a trip to your selling dealer for documenting purposes at least.
wisportsnut
Apr 11, 2024
Thanks flan... I will confirm with the dealer if they just did the y78 recall. If they did, it sounds like you are saying I could clear the code and see if it comes back, right? I do have 1.5 years left on my powertrain warranty thank goodness...
wisportsnut
Apr 11, 2024
Ok just contacted ram and they said the y78 was performed 7/23, so 9 months ago... did that change anything??
flan
Aug 16, 2019
How long did it sit on the dealer lot for sale?
wisportsnut
Apr 11, 2024
They said about 30 days... then they filled it up for my delivery... still on the first tank of fuel, about 3/4 tank left....
flan
Aug 16, 2019
Ok get it checked out, let us know what they have to say.
wisportsnut
Apr 11, 2024
Dealer is saying until they can get it in, it is ok to drive. What do you experts on this forum say?? :)
RamCares
RamCares Team
Mar 25, 2019
While only speculation, it is likely that your fuel injectors will need a diagnosis. Code P026B appears when there is a concern with the injection timing performance of the vehicle’s engine. If the timing of the fuel injection is incorrect, it can result in reduced engine performance. Other possible causes of P026B includes concerns with dirty or malfunctioning mass airflow sensor, exhaust gas recirculation valve (can cause a restriction of air flow to the engine.), a clogged fuel filter, or a concern with the fuel injector control module. If you decide to have your vehicle serviced, our team would be more than happy to work alongside your dealer to confirm the direct cause, and subsequent repair needed to return your vehicle to its proper standing.
Chris,
Ram Cares
I'd keep after the dealer, could be injector issues or ??
wisportsnut
Apr 11, 2024
Chris,
Ram Cares
Thank you Ram Cares... you say reduced performance... I could interpret that to mean it wont damage anything to drive in this condition, it just might not have have the power it should have. Is that an accurate statement? I do have an appt for Wed (It's Friday today) with my local Ram Service Center, I just want to know if I should refrain from driving it until then..... tx
RamCares
RamCares Team
Mar 25, 2019
Essentially
Essentially, yes. However, your safety is our top priority, and we would recommend driving in your vehicle as a last resort until your upcoming appointment. If you would like assistance with your upcoming appointment, we would be more than happy to escalate your concerns to a specialist for a review while your vehicle is being looked at.
Chris,
Ram Cares
wisportsnut
Apr 11, 2024
Hello all, here with an update. On Friday evening I went to move the truck and the check engine light was off. I do have an appt for Wed. Any thoughts on why that might clear by itself?
flan
Aug 16, 2019
If the ecm reads normal parameters for a few drive cycles typically the cel will clear itself. There may be a stored code the dealer can see with their witech scanner.
DP3500
Oct 12, 2020
I am currently dealing with this issue now. Dealt with the codes being intermittent for 6-7 months, finally a new dealer found metal debris in the fuel system. And the only possible cause was from the recall performed 9 months ago. I would have them check for shavings. Now I'm dealing with Ram and warranty to see if they will cover for initial recall.
wisportsnut
Apr 11, 2024
Hi all, the truck was "tested" by the dealer, this was the response..." test is done and all reading submitted to our engineer department based off the readings they have advised us to replace the fuel pressure regulator first, part will be in tomorrow". I will be picking it tomorrow (friday). Will keep the post updated... tx for ali the help!
dgstandard
Nov 27, 2019
I had this code pop up off and on over this past winter. I brought it in to dealer and they just cleared it. I suspect ithe issue came from a poor batch of fuel from my local station. The code would go away after fuelling up at other stations. I made it a point not to fuel up locally for a couple of months now and the code has yet to come back.
