Selectable Tire Pressure Monitoring System (STPMS)
phatboy64
Sep 20, 2022
Nice job! It is like when you get your first pickup truck, you start finding lots of cool stuff you can do with it..
Shots
Nov 10, 2023
Ha ha, I hope not. I spent way more time/money than I should have on my 1st truck... and the 2nd, and 3rd, and so on. As the years have gone by though, I do less to them, but still can't seem to leave anything completely stock. But that 1st one? Oh man, I'd spend hours looking for things to do to/with it.
Good times. :)
Shots
Nov 10, 2023
Anyone know how to REMOVE the sgw bypass?
The instructions say to gently pull the connect while depressing the tab of the connector.
That photo doesn't make any sense. It looks like they're pressing from the female side, which is obviously plugged into the block.
Mine doesn't seem to be working now and I want to test the wires. If I plug the Vlinker into the OBDII directly, it immediately lights up. So either I've got a bad connection, or a short in one of the wires of the bypass. If I can take it out I can hit it with a multimeter to see where the problem is, but I can't get it out.
Any tips?
G Mcpherson
Dec 20, 2020
Yacolt, Wa
Insert a Small Tip Screwdriver as shown and press down on the Tab. Pull when holding it down. It will come out. I shaved mine down so it can be removed without this process.
Any tips?
That image is just the back side of the connector with no wires inserted into it.
CdnHO
Nov 17, 2020
Ontario
Cut the little locking tabs off once you get them out. Makes removing them far easier.
Shots
Nov 10, 2023
Okay, that makes a little more sense. I'll see if I can figure it out with that.
Thanks guys.
Shots
Nov 10, 2023
Thanks for the help guys, I was able to unplug them. I was trying to find a release tap on the outside of the plug, not in a position that sort of looked like it's inside the wire holes. You guys helped me make sense of what I was looking at on the stock phots.
I decided to add a better photo (that actually have wires attached) for anyone else trying to remove the plugs.
I have one of the plug with the barb filed down. Now the plug pulls out of the socket easy enough. It's still snug in there since I didn't remove the tap all together, but there's nothing "locking" it into place. Much better for temporary installs.
Shots
Nov 10, 2023
Now the kicker. I tested the harness. I have good current through all the wires/plugs. Yet the VLink doesn't light up when it's plugged into the harness, but immediately lights up when plugged directly into the OBDII.
I must be missing something, so I'll have to revisit the instructions.
BigRamfan
May 16, 2022
Why don't you just get setup with AlfaOBD or Jscan and set the threshold to whatever you want and/or turn the TPMS off (set to TPIS)?
Hello Brutal, I have a 2023 Ram 3500 and would like to reset the threshold tire pressure alert limits. I do have an AlfaOBD and the bypass cable. What exactly does need to be reset in the AlfaOBD? A certain code or what? Thanks
CdnHO
Nov 17, 2020
Ontario
Assume you have already activated the TPMS. Go to adaptation and search for "tpms". Go to TPMS Settings. Set light load for front and rear to 0 and the max load to whatever you want. I set my front to 65 and my rear duals to 35. I use the door sticker values when I tow the fiver.
