(Set of 6) 20" Inch Cali Summit Dually-Lifted 8x200 Black/Milled Wheels
Flea
Sep 8, 2022
Thinking of getting these for my 22 3500 DRW mega.
Anyone here have them? If so, any issues?
Tips on installation. Any pics you can share?
Looks like I can wrap these with 275 65 R20’s with stock height.
Thats going to ride like crap but they should fit problem free…
Drumminguy81
Oct 31, 2021
They will fit and ride fine. Little rougher than the oem 17's on a dually but the SRW comes with 285x60x20 stock which has a smaller sidewall than the ones you are looking at.. I have personally run the oem 17's and 35x12.5x20 on my Dually and currently run 35x12.5x22 which has a smaller sidewall. IMO the ride quality is effected much more by tire PSI and brand/tread pattern on the tires. I am not arguing that less sidewall is going to be more harsh, but its not enough difference to bother me. Just my .02, H3LZSN1P3R has far more tire experience than I do but I say if you like them go for it. Plenty of people are running that tire wheel size combo and are pleased.
Flea
Sep 8, 2022
Thanks for the info on this guys.
It is well received and much appreciated.
35 12.5 R20’s will fit without rubbing with stock height?
Guess no one here has these wheels though.
Not sure on the width of those wheels (you should have a minimum of 8” wide) but yes they will fit with no rubbing
Drumminguy81
Oct 31, 2021
Im not sure what the offset of the front on those but I ran 35x12.5x20 MT on Fuel Triton dually wheels stock height no rubbing. I will say the tires i had were small for a 35. another thing to look at on those wheels is the rear offset, you may not be able to run the 35x12.5 in the rear depending on the offset they may touch the leafs and or each other. you should be safe with the 275/65.
