Steering wheel controls stop working
relbus
Sep 15, 2020
Chicago
On my 2023 the steering wheel controls stopped working. This has happened about 4-5x. They have applied an update, which got them working for a few weeks. They have replaced the switches on the wheel, which got them working for a few weeks.
They have replaced the entire steering wheel assembly, and they only worked for about 12 hours after that. A few of the visits they determined parts were wrong or had an imperfection, so I had to go back. Each time I went in with non working controls, I left with working controls.
Very annoying. Anyone else have similar issues? Getting tired of having to take my truck in for this.
relbus
Sep 15, 2020
Chicago
They have not replaced the clock spring yet. That was my first thought, but they concluded it was initially the controller, and then the switches themselves. I have a call into the service manager to find out what their next step is.
I do not want to be without my truck while they wait on parts, so hopefully they can order the clock spring and when it comes in attempt the repair.
tchur1
Jun 23, 2021
It seems clock spring is the main culprit for many issues with steering wheel controls. I had mine break my steering wheel heater. Replaced the clock spring and its been great since.
If they have not done that yet, that's where I would go next.
mountainears
Mar 29, 2022
Seems like if they replaced the whole steering wheel assembly they would have done the clock spring. But as mentioned that typically is the issue reported in this forum.
z06psi
Aug 23, 2023
Mine is doing the same. However, it is just the screen controls for the instrument cluster and the buttons behind the steering wheel for the audio controls. The Cruise control works just fine.
z06psi
Aug 23, 2023
Just to add. If I disconnect both batteries everything works for a couple of weeks and then goes off again.
rdesjardins
May 14, 2024
So, I have the exact same issue you have with the screen buttons and back radio buttons. So just disconnecting battery seems to work? My truck is a 2024 RAM 2500 Limited with only 526 miles on it. They said they can get it in for at least a week. How long you remove battery cable. Just quick remove and add back or keep it off for a bit?
SpeyRam
Apr 18, 2023
Washington State
I had mine checked out last week for similar issues at the dealer I bought the truck from. Felt initially like it would be a wild goose chase as I had disconnected the battery and the problem went away like has been mentioned here. However, the service tech found there was an internal service memo (can’t recall the acronym he used but it wasn’t a recall notice) that talked about this and a loose connector in the steering wheel was the cause. He found the loose connector in my truck and so far (~ 10 days) the left side button issue hasn’t returned.
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
those little connectors are in a tight spot inside the wheel. I'd think clockspring right off the bat, though.
