Atty
I did this a while ago and was going to do up a full thread, but I didn't take too many pics of the install, so I didn't think it worth it. However it seems that more and more people are interested, so here's what I have.
The parts list provided below is for my exact truck model you will need to look for the vin of a truck that is the same as yours but that also has the factory surround view camera. this will then allow you to search through OEM parts dealers for the exact parts you need. you can then compare them against what I have listed here. I couldn't have done the install without Jimmy07's help so firstly thanks @Jimmy07 !! The install works as intended from factory (albeit with your own wiring in a couple of places).
The prices listed were accurate as of mid 2020. It's not a cheap exercise and requires some serious dismantling of your truck. this includes door skins, interior roof (as much as needed to get you arm through for feeding a cable to the CHMSLamp/Camera), attaching into the CANBUS and wiring some power wires (with fine wire) to power up the Central Vision Module.
You will also need a security bypass module/cable, AlfaOBD, and a high quality OBD Bluetooth adaptor.
The skills required aren't particular hard, but it takes some time and patience to do. I reckon I did it in about 2 days (not counting waiting on parts that I didn't know I needed/or getting a better Bluetooth adaptor).
You will need to replace the original rear tailgate reversing camera and the tailgate handle as the new surround camera system uses digital cameras and the mount for the cameras is different.
I did the install in stages but all up I'd say it took about 4-5 hours. Then lots of slow driving to get it to calibrate
I'll put a couple of place holder post below this to talk through as much of the process as I can remember.
@Brutal_HO happy to leave the thread unlocked for the moment, unless you feel it would be better to lock it down for the moment.
