jadmt
My buddy has a 2020 PW he got it about a month after I got mine. We camp quite a bit together and he set his up with an RSI smart cap and James Baroud XXL tent. He has a Decked system as well. a few weeks ago we were headed out and he went to pass a semi and he said when he was next to it he thought he was going to crash and thought he had death wobble. I was in front of him and never had an issue passing it hit probably 85mph in doing so. Any way fast forward last week we went camping again and I was following him and he was all over the road. went thru a set of S turns at 55 mph which was posted limit and he again was all over. I told my wife "wow I bet he **** his pants there" I went through no bobbles or wobbles. We both run E rated 35's on AEV wheels. Both run the same PSI when loaded ie 55psi. he has Nitto RG and I have Toyo RT so very similar tires made on the same carcass. When we came back we pulled into a cat scale to see the weights fully loaded. We filled up before weighing. He was at 9500lbs I was at 8840lbs. His payload on the door says 1300lbs (he has a level 2) and mine says 1565 (I have a level 1) seems odd there is 265 more weight with a level 2 then level 1. Leather can not weigh that much more. Really suxs that a weekends worth of camping stuff puts you that far over the gvwr. He ordered a Thuren rear track bar as soon as we got home and is calling Carli tomorrow. CJC had a you tube video saying airbags don't really work. What are you guys running heavy doing to help your on highway ride? Anyone know if OEM 2500 tradesman coils have the same free length as PW coils? We both have ARB 50qt fridges and on this trip both were carrying a yeti 50 qt cooler with 20lbs of ice. This how we are both set up. I have 12500 miles on mine and has around 11000 miles on his so shocks should not be worn out.
