Thank you, I can't find the antifreeze leak. I can smell it, and I have to fill the reservoir once in a while.that's the ac condensation drain.
How often is once in a while? Any signs on the water pump weep hole?Thank you, I can't find the antifreeze leak. I can smell it, and I have to fill the reservoir once in a while.
Engine oil is clean.
Every 400 miles I haveto add a quarter of antifreeze, water pump isn't leaking.How often is once in a while? Any signs on the water pump weep hole?
Thats a significant leak you should be able to see the antifreeze or significant staining where it is leaking. If the A/C drain is leaking antifreeze like you say then the heater core needs replacing but you should have a sweet smell on the inside of the truck and when using the vents your windows would be fogging upEvery 400 miles I haveto add a quarter of antifreeze, water pump isn't leaking.
It won't smell inside , but yes I see liquid coming out from the outlet showing in the picture.Thats a significant leak you should be able to see the antifreeze or significant staining where it is leaking. If the A/C drain is leaking antifreeze like you say then the heater core needs replacing but you should have a sweet smell on the inside of the truck and when using the vents your windows would be fogging up
That should be just water coming out, if it does not smell inside it’s not a heater core failure. I would recommend having the coolant tested for combustion gasses you can buy the test strips.It won't smell inside , but yes I see liquid coming out from the outlet showing in the picture.
