Loosen the screw on the inside of the door at the end the hole is slotted it will allow it to expand and contract normally.I also have 4 doors that have this same issue... @RamCares how do we handle this issue? 2020 Ram with 49k miles & extended warranty to 10 years & 150k. Please advise asap. Thank you!
I'll try and hope this works!! Thx!Loosen the screw on the inside of the door at the end the hole is slotted it will allow it to expand and contract normally.
We hope that the solution given by @H3LZSN1P3R proves useful. If not, we will be more than happy to see where we can assist with this concern. If issues persist, reach out to us, and we will do our best to aid.I w
Ok, I loosened the screw and this has not moved any amount. It is sitting in the sun to see if any changes. Here’s the current pics of front doors & rear doors do not show warping yet.We hope that the solution given by @H3LZSN1P3R proves useful. If not, we will be more than happy to see where we can assist with this concern. If issues persist, reach out to us, and we will do our best to aid.
Chris,
Ram Cares
It should sit flat after a bit thats all i had to do with mineOk, I loosened the screw and this has not moved any amount. It is sitting in the sun to see if any changes. Here’s the current pics of front doors & rear doors do not show warping yet.
After how long baking in the sun?It should sit flat after a bit thats all i had to do with mine
About 2hrsAfter how long baking in the sun?
I have let it sit in sun for 3 days now with screw removed and zero change thus far. @RamCares Please advise on how to get these warrantied replaced. Thank youWe hope that the solution given by @H3LZSN1P3R proves useful. If not, we will be more than happy to see where we can assist with this concern. If issues persist, reach out to us, and we will do our best to aid.
Chris,
Ram Cares
Hopefully they swap them out for you.I have let it sit in sun for 3 days now with screw removed and zero change thus far. @RamCares Please advise on how to get these warrantied replaced. Thank you
I hope so to! Seems to be the right thing to do.Hopefully they swap them out for you.
We can definitely look into this for you. Please send us a private message including your VIN, and current mileage for us to see if any coverages exist for your concern.I have let it sit in sun for 3 days now with screw removed and zero change thus far. @RamCares Please advise on how to get these warrantied replaced. Thank you
I did that and it expanded so much that the ends conflicted, wouldn’t allow the doors to open/close without tearing them up. Now, they really look like poo.Loosen the screw on the inside of the door at the end the hole is slotted it will allow it to expand and contract normally.
So it seems ram just let me know there is no coverage for my belt mouldings warranty replacement for my truck. 2020 Ram 50k miles. I also just advised them i have an extended warranty for 10 years 150k miles.
Wonder why they would decline warranty replacement for mouldings?
ThisAnother reason why extended warranties are a scam. They try to scare you in the finance office that everything is expensive and complicated only to deny small things down the road.
