Adding the OEM hidden tailgate strut to any trim.
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
Has anyone gotten a bad damper or had one go bad? I installed the OEM one I bought, it worked a handful of times very soft/smooth then it started only slowing the drop slightly but the gate still bounces a little at the end because it drops harder than I would expect?
They’ve gone bad on all of our tundras. They will all eventually go bad.
44Dan44
Nov 27, 2022
Maryland
Pulled this pic from Ram and posting it because it's 2am and I've nothing better to do. Just gives an easy view perspective of the linkage and how it relates with the dampener, thought it might be helpful for someone about to install a dampener.Image 12-14-22 at 11.07 AM.jpg
jsalbre
Oct 29, 2019
ID
That's a lot of force that little strut is resisting. Pretty impressive.
Milly
May 29, 2023
Just did this to my 2023 Bighorn 2500. Took 5-10 minutes. Ordered from EBay for $41 free shipping. Worth it.
dmhines
Nov 18, 2022
Pulled this pic from Ram and posting it because it's 2am and I've nothing better to do. Just gives an easy view perspective of the linkage and how it relates with the dampener, thought it might be helpful for someone about to install a dampener.View attachment 48778
Interesting picture .. I added the strut to my Tradesman .. and the UP arrow indicates the dust protector should be on the bottom .. not the top ...
44Dan44
Nov 27, 2022
Maryland
Yep! I made note of that when I did mine. Definitely down for the HD, contrary to the Ram graphic. I suspect @dieselscout80 is correct, maybe meant for the 1500's or maybe older HD's.
jak
Feb 20, 2023
Western Mass
If you remove the tailgate do you have to unhook the damper or just remove as you normally would?
