loveracing1988
- Joined
- Feb 16, 2021
No, the P is missing but I wasn't able to find anything search wise until I got rid of the P.There’s a number missing from that part number.
So what would plug into it if it is for trucks without lane sense?Got it now. You were missing a 5 is your post-68485758AA. It’s the jumper harness used in trucks that don’t have the steering torque overlay module (electric steering box for lane sense).
Nothing. See my reply aboveSo what would plug into it if it is for trucks without lane sense?
Just make a decision between Baja and diode dynamics and post the results. I can't decide either but I keep learning toward DD.Parts ordered...now to decide Baja, Diode, Rigid, etc. - any suggestions on the ultimate LED fog light?
I’m sure you can’t go wrong with either.Parts ordered...now to decide Baja, Diode, Rigid, etc. - any suggestions on the ultimate LED fog light?
I have a 2021 tradesman 3500 and wanting this same set up. Do you have the part numbers for this setup? Thanks In advance!
I have a set of diode dynamics pro fogs sitting in my garage waiting for the factory bezels, brackets, and switch to show up.Purchased bezels.. for those of you who didn't use an OEM fog, what fog light are you using to fill the hole?
If you use oem fogs or Baja designs you’ll need the factory bracket as wellPurchased bezels.. for those of you who didn't use an OEM fog, what fog light are you using to fill the hole?
Does anybody know if you get the stock led fog lights and bezels, do they also require a bracket? The pictures of them online look as if the stock led fog lights have the "bracket" part built in like they will just bolt up.If you use oem fogs or Baja designs you’ll need the factory bracket as well
I have a set of brackets and halogen bezels, if anyone needs them.
19 and up
Anyone know the part number for the fog light wiring harness for 2019 ram 1500 new style
