Fog light for 2019 Tradesman
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
No, the P is missing but I wasn't able to find anything search wise until I got rid of the P.
Got it now. You were missing a 5 is your post-
68485758AA. It’s the jumper harness used in trucks that don’t have the steering torque overlay module (electric steering box for lane sense).
Jimmy07
Apr 5, 2020
I believe these are the two connectors you are seeing-
That jumper harness is labeled as “without steering torque overlay module”. I’m guessing that means that it comes with a dummy resistor plug plugged into the connector that has the canbus c circuits, since they’re not being used.
loveracing1988
Feb 16, 2021
So what would plug into it if it is for trucks without lane sense?
Greenhills
Mar 11, 2021
Canada, Alberta
Is it possible for someone to confirm the size of the opening on the factory foglight bezels? I ordered the bezel and will be wiring up my own aftermarket fogs. I just wanted to order foglights while I was away at work, so I can get them installed sooner.
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
Parts ordered...now to decide Baja, Diode, Rigid, etc. - any suggestions on the ultimate LED fog light?
I’m sure you can’t go wrong with either.
I’m happy with the Baja SAE squadrons I added to my t-man. They have a nice pattern and really fill in under the low beams, low and wide. ( My driveway is angled, that’s why they appear to be aimed high) 538D3247-5978-4ECA-A27D-5E0C3474C0FD.jpeg
loveracing1988
Feb 16, 2021
Purchased bezels.. for those of you who didn't use an OEM fog, what fog light are you using to fill the hole?
I have a set of diode dynamics pro fogs sitting in my garage waiting for the factory bezels, brackets, and switch to show up.
Nd79
Jan 11, 2021
Colorado
If you use oem fogs or Baja designs you’ll need the factory bracket as well
Does anybody know if you get the stock led fog lights and bezels, do they also require a bracket? The pictures of them online look as if the stock led fog lights have the "bracket" part built in like they will just bolt up.
farmallboy
Stump Killer
May 23, 2020
Anyone making LED pod brackets for 5th gen yet ? Seems like that would be the way to go.
4wllr
Apr 25, 2021
Anyone know the part number for the fog light wiring harness for 2019 ram 1500 new style
