John Jensen
- Joined
- Feb 11, 2020
You said it so well. Thanks for clarifying what I've been trying to convey.If you read through the directions and look at the corresponding pictures it isn't as clear as it should be.
Step 3 notes to remove the factory bumper bolts and install the bottom brackets. It doesn't show exactly which bumper bolts nor does it show the brackets in question or the orientation to install?
If you look at the SteelCraft instructions (which I have attached for reference) they are much clearer in regards to exactly which bolt to remove and what orientation to install the brackets. Also worth noting, the SC instructions show exactly what each bracket is supposed to look like.
The difference between the instructions (RH is 1 very vague page, SC is 5 detailed pages) and the build quality of the mounting brackets (RH appears to be flat bar bent to fit, SC is gusseted plate) should speak for the overall quality of the product.
I'm not here to fight/argue over the instructions or who knows how to install what. Most of what I have stated is my opinion based on ACTUALLY INSTALLING the Steelcraft product on my truck. Take that for what it's worth.
It seems some want to challenge statements rather than respond to the question or problem.
Your and Chrisminx replies spoke my dilemma, much appreciated.
